Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Please check jpeg facing problem to do this type of drilling with G83 drilling cycle..z axis not going to clearance plan to avoid accident please advise..
