hakdemir
GPOST
I am using Creo Parametric Release 8.0 and Datecode8.0.5.0
I will write Gpost for Siemens 840 D control units, but I didn't get the gpost output as below
CS_TOOL("T60")
CS_TP("T11")
When I got the gpost output, I got it as below
T2 M6
T1
How can I change Tool output as CS_TOOL and CS_TP in the Gpost
CS_TOOL= Tool to use
CS_TP=a next tool
Hi @hakdemir,
Please refer below article for more information
How to replace the register name in the machine code with another register name, which is already in use in GPost
Hope this helps!
Vipul
Hi @hakdemir,
Hope this helps!
Vipul
hakdemir
(To:VipulT)
Thank you
