Hi Guys, can someone tell me if i can stop these 00_BUW layers from being created when i make an EMX moldbase?
I thought i could go into each plate and component, and get rid of them, but they still show up once I hit Assembly definition button. And then i get more once I add in mold plates.
Is there a config hidden somewhere? Or am I stuck with these everytime I use EMX?
Jay
Hello Jay,
this is very easy to configure. Set the EMX option USE_RULEBASED_LAYER_CONCEPT to YES and go to your emx_user_config_path or if you don't have one in your installation under configuration. There you will find a folder called templates. In it you will find a part and an assembly called rule_layers. Inside these are defined the slides which are created by EMX when the option is set. Here you can define your layers by you own.
Kind regards
