HARNESS DRAWING PROCESS -GG.xlsx
GopiGanesh
Hello Everyone,
I have prepared a spreadhseet contains over all process flow for creating Electrical Harness Drawings. Please correct me if something missing out...
This process flow contains Four major modules...
1) Wiring diagram in Creo Schematic
2) Cabling in WF5
3) Manufacturing
4) Drawing
please find the attachment for your Reference.
-GG
Hi Gopi...
Thanks for adding me to your "friends" list. I've reviewed your spreadsheet. Although you could add more detail and some of the steps can be moved into a different order depending upon preference, overall you're on the right track.
I wouldn't even try to refine it much more at this point. You may get better insight into the process by actually trying a simple harness by running it all the way through. I'll help any way I can.
Thanks!
-Brian
