Horizontal Setup
ptc-554711
Horizontal Setup
Hello all, I am using Creo 2.0 and I have a job that requires drilling around the perimeter on a horizontal machine, I would like to set my coordinate system at the center of rotation, and use a single coordinate system rather than a unique one for every hole position, is this possible?
Thanks in advance!
If the holes are evenly spaced you could drill the first hole and then use the pattern feature. With this you could either use the original CS or have it output a new one for each hole.
