How to Generate Fine Boring G76
ScottJohnson
The bore cycle in Creo Parametric 2.0 only seems to generate CYCLE / BORE which is G85. We need to bore, orient, back-off, and retract with G76. orient_angle and jog_dist doesn't output. Any way other than an Auxiliary Sequence all with CL STATEMENTS?
I think I found an answer myself. I created a custom cycle CYCLE/FINBOR and modified my post processor and the output looks to work.
CYCLE / FINBOR, DEPTH, 0.944882, CLEAR, 0.200000, IPM, 3.300000, DWELL,$
SECONDS, 0.100000, JOG_DIST, 0.005000
GOTO / 0.0000000000, 0.0000000000, 0.0000000000
CYCLE / OFF
and get through the post:
G76 X0 Y203.2 Z-24. R5.08 Q.127 F83.82
N9 G80
3 REPLIES 3
CYCLE / OFF
N9 G80
I was going to suggest that you might need to do some post-processor customizing, but you've found that yourself. There are a number of things that I've added over the years that could only be addressed this way (like using tool comments to build a list of tools used, etc.) It can be a frustrating experience debugging, but getting the things to work is very satisfying. Hardest part is finding documentation of the functions available.
razmosis
(To:ScottJohnson)
Do you mind sharing how you modified the post?  By chance, are you using GPOST from Austin NC?
Thank you,
Matt
