HI,
I’m having trouble generating NCL code for PostProcessor on the Mill turn machine. The machine is equipped with milling and turning heads as well as two spindles. I need advice on how to properly generate NCL code for both the upper and lower heads of the machine.
If anyone has experience or tips, I’d greatly appreciate your help.
