How to control writing of feed rate to each move line?
PATAVERY
Our Milltronics post processor is writing the feedrate to almost every line. It looks something like this:
N00058G3F8.X.6895Y.1057I.0197J-.0035
N00060G1F8.X.9139Y.0662Z.13
While our FADAL posts something like this for the same part
N0280G3X.6895Y.1057I.0197J-.0035
N0290G1X.9139Y.0662Z.13
Where is the "toggle" in the Gpost generator to turn writing the feedrate to each line on and off?
I cannot seem to locate it.
There are a few things you can check.  Open the post in the Option File Generator and go to the Machine Tool Type -> Type, Specs & Axes -> Specs page.  In the top right see what the setting is for Motion Register Modality.  If it is set the the second option you will get F codes on every block.
Fred
2 REPLIES 2
Fred
Thanks Fred. I knew it was in there somewhere. I hope all is well with you.
