Hello, I'm trying to make a stack in Creo, but the button to start printing is disabled.
USB is currently connected.
Is it a problem that requires a separate license? Or is there another problem?
Thank you.
Creo Additive Manufacturing Extension (AMX) extension is an additional license. If you do not have AMX this article explains the free functions.
https://www.ptc.com/en/blogs/cad/additive-manufacturing-creo-base-package
Thank you for your reply.
I checked and I had a license. Is there any other reason why the button was disabled?
Can I connect the printer only through the network?
