With Pro/Piping you can route a pipeline through a long and complex 3D path.
Sometimes you are forced to install one elbow hose fitting at each end of the hose.
Howcan Iget from Pro/E theangle orientation between elbows required at manufacturing the hose to avoid having to twist the hose later at final assembly?
I know that you can run a Pro Piping report that shows al the twist angles of each individualpipeline segment.
Is there an easy and fast way for Pro/E to do kind of a sheetmetal flat pattern of the hose and report the angle between the two end connectors?
I'll post a summary of your replies.
Ronnie Shand
You can just download some elbow fittings from McMaster Carr or Parker and put a point at the start of the fitting opening and a point at the end of the fitting opening. If you then use the fitting in your assembly and use the attached procedure to create the tubing then you will have an accurate length reported in the report?
