How to revolve a 3D edge ?
SylvainA.
I and my colleagues have to design turning and milling tools, thus we often need to check the shape generated by these tools during machining.
As the cutting edges are sometimes not contained in a plane and/or not in a plane containing the axis of revolution of the tool, we cannot simply use the Revolve feature.
The easiest way we found is (in WF5) :
1. Copy/Paste a cutting edge
2. Copy the copied edge
3. Paste special with Rotate transformation (10°) around the tool's axis of revolution
4. Pattern it every 10°
5. Make a boundary blend of all these copied edges
The question is: IS THERE A SINGLE PRO/E FEATURE ABLE TO REVOLVE A 3D EDGE (not contained in a plane) AROUND AN AXIS ?
Thank you.
Edthewrist is right.
Make sure you select only one boundary chain (circle) and one inner chain (your 3D curve) while creating the surface.
~Jakub
16 REPLIES 16
Patriot_1776
(To:SylvainA.)
I've run into this before. I feel your pain. I can, for instance, model a 3D trajectory to be machined by a ball end mil, but the resultant geometry does not equal the modeled geometry. This is a known issue for which I know of no easy solution.
Thank you for your interest Frank.
Our case is a litte bit easier than yours: we just need to visualize the shape generated by the cutting edges with the tools in a steady state, with no feed, but rotating.
A colleague of mine sometimes exports his mills to Unigraphics in order to generate this revolved geometry and then re-imports it in Pro/E...
But I also missed the "milling" feature during designing special tools.
Patriot_1776
(To:SylvainA.)
Why not use a revolved surface or cut then?
Because the revolve feature needs a section and an axis of revolution contained in the sketching plane, and in my case the edge is not contained in a plane and/or this plane does not contain the axis of revolution.
Here is a simple example of what I need to do (machining a chamfer with an SNMM insert).
Have a look at the cutting edge's orientation.
It is quite harder with this kind of mill:
http://www.ceratizit.com/2920_ENG_HTML.htm
Edthewrist
6-Contributor
(To:SylvainA.)
You can do this using style feature. (You need an ISDX license)
SylvainA.
(To:Edthewrist)
Could you explain me how to do it?
I am in the styling menu but I can not figure out how to make a revolved surface...
Thank you
~Jakub
SylvainA.
(To:James62)
Thank you.
It is not as straight-forward as I expected it to be but it works fine !
kerzen
6-Contributor
(To:SylvainA.)
Try to use variable section sweep! It will work. First you have your 3d curve:
You will need to create a curve instead of centerline of rotation and you will use it as first curve and then yo will pick your 3 d curve as second one.prt0001_2.jpg
Then go to sketch and create sketched circle with center on first curve and diameter will be driven by your 3 d curve.prt0001_3.jpg
In this way you can create surfaces or solids. Sometime you will need to use constant normal direction for plane control.prt0001_4.jpg
Variable section sweep is rely powerful tool.
If you have any further questions please ask!
Best regards Klemen
SylvainA.
(To:kerzen)
I tried it, but in this case it does not seem to work (the chain has multiple points at the same "level"):
kerzen
6-Contributor
(To:SylvainA.)
Can you send me 3d model, please! I will see why is not working!
SylvainA.
(To:kerzen)
I cannot, but here are a front view and a right view of the cutting insert I used:
kerzen
6-Contributor
(To:SylvainA.)
Try to replicate your situation, and it worked, just split it into two surfaces.prt0005_front.jpgprt0005_right.jpgprt0005_3d.jpg
SylvainA.
(To:kerzen)
OK.
Thank you.
Patriot_1776
(To:kerzen)
Looks like you need way more rake in that tool insert.........
Actually, the only working cutting edge of this insert is the one which is not selected
