did any of you has an experience with the following topic ?
i searched the knowledge base and found only reference to old documentation.
Many thanks,
1.) you have to own commercial license of vericut
2.) you have to ask Vericut Support
yes, you can integrate vericut with any version of creo parametric.if you have to own a commercial license of Vericut
