How to use Local Milling in Creo 3.0?
vdao
I am using Creo 3.0 to make program for CNC machine, but Local milling is not work with Volume milling! How to fix it? (How can I use Volume milling to replace it?)
BillChapman
(To:vdao)
You need Creo 3 datecode m070 or later for this to work.   See CS191225 for the work around if you do not have access to this.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS191225
