Increase Ram Usage
mwimberly
6-Contributor
Increase Ram Usage
I am drawing a blank, what is the process to increase the amount of RAM
used by ProE? I have a 64bit machine with 8 gig of RAM and it is only
using 2 gig.
TIA.
Michael Wimberly
Engineering Applications Support Specialist II
Security & Survivability
BAE Systems Land & Armaments
9113 Le Saint Drive
Fairfield, Ohio 45014 U.S.A.
(513) 881-4843 Direct
(513) 881-5087 Fax
(513) 881-9800 Main
It's Friday, right? Close enough.
Create a more complicated model and it will use more RAM.
Seriously, the main thing you need is a 64bit OS, otherwise there is a
hack that should be findable by Google. With a 32bit OS all you can get
is about 3Gb.
> RAM used by ProE? I have a 64bit machine with 8 gig of RAM and it is
> only using 2 gig.
> TIA.
> Michael Wimberly
> 9113 Le Saint Drive
> (513) 881-5087 Fax
> (513) 881-9800 Main
> - <">mailto:->
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
