Just Loaded Creo3.0
SteveLucas
Just Loaded Creo3.0
Wow,
Quite a Different Look to the icons and the new trajectory is nice and clean looking. I like it so far. I am Just looking right now probably won't start using untill after they get all the mold stuff running this fall or winter.
6 REPLIES 6
Are you running other versions on a fixed license? Just gathering loading options.
SteveLucas
(To:TomD.inPDX)
Antonius,
Yes, I am Running Creo2.0 M110(what we are running for Production) And Creo 3.0 just for testing on a fixed license. Only 1 can run at a time. So when I get a few minutes free I go in and play with Creo3.0. It helps If and when we switch over to Creo3.0 to know it already.
Thanks Steve. I would be most interested in knowing about problems with loading and running both versions.
SteveLucas
(To:TomD.inPDX)
Antonius,
No Problems at all... at least in my load...Uses the same License files and config files as Creo2.0. I probably should have put Creo3.0 in a separate directory but I forgot and just let it load and everyting seems to be behaving fine. I just remembered I did get a new license file because of a hard drive crash but I was not sure i needed to? anyway the new license file runs both versions fine.
Thanks again.
I just loaded Creo 3 as well. The new UI's are great but I guess after wating so long between releases I thought there would be more new "stuff". There are a lot of little things that I think can really make this software better.
I created a product idea for the ability to add a shank diameter to cutting tools. For me this would be very helpful in collision detection. Most softwares I've used (MasterCAM, CamWorks, etc.) have had this feature for a long time. If you can vote yes for this enhancement if you agree with it and I will vote yes for whatever other enhancements this community thinks is useful.
