I used NCpost for years with curve fitting turned on within the post
with a tolerance of .0006. The curve fitting worked great. It handled
everything including helical leadin's. Trusted it completely.
Now I have switched to Gpost and I can't make it work for crap.
I have spent hours changing and playing with all the tolerance
parameters and to no avail. I really dislike having to put a cl
command in the toolpath just to turn it on. Maybe it woks ok
if you can get it setup properly. If someone uses curve fitting
please send me a sample post.
Robert Whitted
Contract CNC Programmer
770-228-6087
