Manufacturing - Hurco Postprocessor
japrenticeuk
Greetings
Does anyone here have a postprocessor for Pro|NC that will work with a Hurco mill (specifically the VM1)?
My problem is that I have used the option file generator and created a Post that seems fine except for tool changing. I cannot pursuade it to put the G43 Hxx that applies the tool length offset in a separate block before the Z move that uses the new tool. The Hurco barfs if they are combined.as in block N45
N30 T1 M06
N35 S1000 M03
N40 M08
N45 G0 G43 Z5. H1
N50 X0. Y-26.
TIA
John Prentice
Hi John,
Maybe you better ask for it in the Pro/Enginner CAM board...
http://portal.ptcuser.org/p/fo/si/topic=11
Daniel Santos - Sr. NC Programmer / CAM Support
Liebherr Aerospace Brasil
