Hello community,
I am using Creo version 6 (educational edition) for a couple of days now and designed a part which I would like to manufacture by using some milling processes. To do so, I click on file -> new -> manufacturing -> NC assembly -> ok, but the screen with the manufacturing options doesn't appear.
Could someone please give me an advice of how to solve this issue? 🙂
Thanks for your support.
MLC89
Educational and commercial models/licenses are not compatible. I am not sure that manufacturing is supported in the educational version. Are you trying to manufacturing this in the school's machine shop?
You could also contact your local VAR and see if there is something special that you could do for manufacturing at an educational facility.
Thanks for your fast response.
I would like to simulate the milling process (by means of CAM) in order to see how long the different steps would take.
I will contact the local VAR and check for the compatibility between educational version and manufacturing mode.
