Material suggestions for flat spring, spring clip, or leaf springs?
Hi Pro-E Users,
I have a question for you about materials and drawing notes for manufacturing custom leaf springs. The thickness will probably be .031 inches or less, and it is not used a corrosive environment.
I need to specify a spring steel (ex: AISI/SAE 1074/1075) in a drawing for a custom leaf spring. Carbon Steel 1074 has a yield strength ~ 73,000 PSI ( This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
