Does anyone know how to change the color of a mill volume or mold volume while in shaded mode?
I can change the color in wireframe, but it remains blue while shaded.
Thanks in advance for your help.
Dan
I added a product idea for this to be considered in the future. Please visit it and vote on it.
Dan
Hello Dan,
I saw you opened a case with PTC Technical Support and the answer was, that it is not part of the current functionality (see article CS216399).
If you follow the advice from the article and open a Product Idea, let us know the link, to vote on it.
I can also put the link into the article to generate more traffic to this product idea - usually the best we can do, to get it higher in the ranks.
A general hint to all:
If there is a Product Idea existing, which applies to a functionality documented as "non-functionality" in any article, add a comment to the widget of the article with the link to the Product Idea. This should allow us to update the articles and this way help in two ways:
Gunter
Dan
Thank you Dan!
I added the link to the article and marked your post as Correct Answer, as this is all that can be said so far.
Now let the votes generate attention for the idea.
Gunter
