Milling Extension license issue
bcomstock
Every time I open Creo Prismatic and want to use the Multisurface Milling Extension I have to go into the options menu, refresh the licenses, and select the correct license. Is there a way to make this persistent so I don't have to do this every time?
Brian,
you have to configure your Creo start command properly. This means you have to run reconfigure.exe and modify your startup command configuration.
Martin Hanak
Martin Hanák
Brian,
Martin Hanak
Martin Hanák
Brian,
Reconfigure Creo by executing reconfigure.exe from <Creo 2.0 Install dir>\parametric\bin > Next > Next > Customize > Command configuration > Edit > Move license from left to right > Ok > Ok > Install.
