Modelling standards for manufacturing
SamuelMoses
Hello Everyone,
I posed this question to the manufacturing group and only received a few
replies so I thaought I would ask this group for help.
We are starting a project to determine modelling standards for our
corporation. As part of this project we need to determine if there are
any modelling techniques or processes that people are using to make the
manufacturing side of the business easier.
Some suggestions I have received are: don't make interior radii for which
there isn't a standard ball end mill, rounds at the end of the model is
good, don't make huge complicated one feature rounds just because you can.
A few simple ones are always better.
Are there other practices you would be willing to share? Any input would
be appreciated. Thanks.
Sam Moses
Caterpillar Inc.
Thank you for your responses to my inquiry about modelling standards for
manufacturing. Here is the original question and a summary of the
responses I received.
Sam Moses
Caterpillar Inc.
Original question:
Responses:
I have read your post and agree with some of the practices recommended (#4
in particular). I don't consult in this area but we have extensive
experience machining 3-D parts. Though we don't currently use Pro/NC we
have two seats and are gearing up to do that. As for the radii situation
mentioned, use a slightly larger radius than standard available ball
mills.
When machining solid and surface models the tool will machine any area
that
it can physically fit into and as long as the corner is smaller than the
diameter of the tool, it will cut it.
A remark on asymmetric tolerances & dim/bound > middle vs. inheritance
features. As of WF2, according to the release documentation, a part can be
designed with asymmetric tolerances, and manufacturing can work on a derived
part with symmetric tolerances, derived from the first part with inheritance
feature.
Regards, Hugo.
"Samuel Moses" <-> wrote in message news:59795@model...
> Sam Moses
> Caterpillar Inc.
> Original question:
> Responses:
> mills.
> that
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
