Multiple Manufacturing Facilities
bnoll
3-Visitor
All,
How is one handling multiple bend tables in one sheet metal part? I
have a part that needs to be manufactured in multiple manufacturing
facilities, both having different bending allowances and unit systems.
The only process I have found is the "global" sheet metal part can in
fact not be created as a sheet metal part it must be done as a solid
model. Then using the inheritance feature one can convert it to sheet
metal selecting the bend table they so desire.
Problem with this is, telling a user they cannot use the sheet metal
package to create their parts. Creating them as solids is a lot more
cumbersome.
Any thoughts?
WF3 M170
Ilink 3.4 M060
Brian S. Noll
Sr. Engineer/Technologist, Design Services, IT
Johnson Controls, Inc. <http:%5c%5cwww.johnsoncontrols.com%5c>
Tel: 717.771.7587
Fax: 717.771.7270
- <">mailto:->
bfrandsen
6-Contributor
(To:bnoll)
Brian,
I am not a sheetmetal guru but for each feature you can define whether to
use the overall part bend table or a specific bend table for that feature.
Would that not solve your problems?
Bjarne Frandsen
"Brian S. Noll" <->
07-10-2008 19:59
Please respond to
"Brian S. Noll" <->
To
cc
Subject
[proecad] - Multiple Manufacturing Facilities
All,
How is one handling multiple bend tables in one sheet metal part? I have
a part that needs to be manufactured in multiple manufacturing facilities,
The only process I have found is the "global" sheet metal part can in fact
not be created as a sheet metal part it must be done as a solid model.
Then using the inheritance feature one can convert it to sheet metal
cumbersome.
Any thoughts?
WF3 M170
Ilink 3.4 M060
Brian S. Noll
Tel: 717.771.7587
Fax: 717.771.7270
-----End Original Message-----
