NC Check option
ptc-2167251
NC Check option
Hello
when playing toolpath, the NC Check option is gone. (to play Vericut)
I believed it was there some days ago....
Maybe someone can clear this up?
thanks,
bern
6 REPLIES 6
SteveLucas
(To:ptc-2167251)
Bernard,
What are you using wild fire or Creo ? With creo you should be able to highlite the sequence or operation you want then right mouse button and down at the bottom should be material removal Simulation (vericut) or play path(nc check)
Hello Steve;
I'm using WF 5.
I right click the sequence, then choose play parh anf the little window pops up....
but I think there was some Ncheck to turn on..?
I know vericut, but what is ncheck?
I thought the default setting for ncheck was vericut in the config.pro.
(ncheck_type)
thanks
bern
SteveLucas
(To:ptc-2167251)
Sorry I don't have WF5 anymore Just Creo2.0 so I won't be much help. You are correct there is a config option to set the nccheck type to either vericut or nccheck. Not sure what your problem is if you have that option set to vericut?
Steve
Hi Bernard
So am I correct to believe that you had Vericut running, but now it doesn't.
Question, what has happenned in the last few days..did windows perform and update. have you altered the setup in any way
What type of license are you running, is it being shared.
Can you check and see if the Vericut floating module is loaded when WF5 starts.
Peter
all is working now...
thanks,
bern
