Can help too much with the Legacy PP issue... sorry...
"Also, is it WF4 or WF5 that they put the manufacturing info in the .asm file? "
WF5 does that. In fact the MFG file in previous releases stored only metadata, such as tool manager tooling, parameters, workcell details, etc. The core was in the.ASM file, since material removal, MFG Geometry and toolpaths are basicaly assembly features by design. Material removal for example is a assembly cut feature. 🙂
HTH,
Daniel Santos - CAM Support
