NCL gouge check control for transition from NC Sequence to another NC Sequence in CREO5
sstavruk
In Creo Parametric 5.0.4.0 not always gouges are found in areas of transition from one NC sequence to another NC sequence. To detect them, it is now necessary to select a specific step value (not tolerance) when checking the CL file for gouges. I propose to improve the CREO functionality for detecting gouges in the CREO (this is not a question of ModuleWorks), irrespective of the gouge check step in the toolpath transition sections from one NC sequence to another NC sequence.Manufacturing resultManufacturing resultGouges check. Step = 0.5Gouges check. Step = 0.5
If step of gouge check = 1 and another, gouges don't found!
0 REPLIES 0
