PRO Molding
Not applicable
PRO Molding
This is a question in reguards to PRO Molding, In the "Automatic Workpiece dialog box" no matter what we do the bottom half is grayed out and you can not enter any data? Any thoughts about this? Todd
WillyC
(To:)
Have you selected a coordinate sys for locating?
opovoa
(To:WillyC)
You should check on the install, that the moldapp options on the install menu have been selected (it's the second menu, it's the same menu were we select if we want to install mechanica, and help files). cheers. Olavo
