Post processor modify tnc426 Heidenhain
asifcad
Can someone help me. How to modify pp for desire drilling cycle please check attached jpeg
8 REPLIES 8
Civodul
(To:asifcad)
Which post processor generator you use ?
asifcad
(To:Civodul)
please check attachment
Civodul
(To:asifcad)
Send the file uncx01.f**, and I show you the changes to be made.
asifcad
(To:Civodul)
sir very for late response ..i am still in problem regarding post processor..are you still willing to guide me
regards
asif
asifcad
(To:Civodul)
please check attachment for post processor
regards
fisa
Civodul
(To:asifcad)
Fisa,
you use ISO code or conversational code ?
The sent PP generate ISO code....
Send me ncl file with drilling cycle and the CN code output.
asifcad
(To:Civodul)
 thanks for your reply..yes i am using iso post processor..most of cycle .which i generate thru this pp is working fine ..except drilling taping reaming etc cycle...by default the current processor generate drilling cycle with this format.
%DRILLING_1 G71
N1 G40 G90
N2 G30 G17 X-100 Y-100 Z-75
N3 G31 G90 X100 Y100 Z3
N4 G17 T17 M6
N5 S3 M3
N6 G00 X31 Y-12 M8
N7 G00 Z20
N8 G83 P01 2 P02 -4 PO3 -1 P04 0 PO5 100
N9 G00 X31 Y-12 Z-8 M89
N10 G00 Y77 M99
N11 M9
N12 M5
N13 M30
N999999 %DRILLING_1 G71
but i dont want to use this canned cycle due to some restriction(2nd setup clearance not available ) in this format  ..
..i am sending you conversational post processor which i want to use only for drilling taping and reaming purpose  please if you can update it or guide me how i can update on below mention format
0 BEGIN PGM 201RM10 MM
1 BLK FORM 0.1 Z X-400 Y-400 Z-75
2 BLK FORM 0.2 X+400 Y+400 Z+3
3 TOOL CALL 1 Z S80
4 CYCL DEF 201 REAMING ~
Q200=3 ;SET-UP CLEARANCE ~
Q201=-30 ;DEPTH ~
Q206=30 ;FEED RATE FOR PLNGNG ~
Q211=0 ;DWELL TIME AT DEPTH ~
Q208=80 ;RETRACTION FEED RATE ~
Q203=+0 ;SURFACE COORDINATE ~
Q204=50 ;2ND SET-UP CLEARANCE
5 L Z+50 R0 F3500 M3
6 L X-262.99 Y-146.925 M99
7 L X-303.002 M99
8 L X-305.002 Y+130.225 M99
9 L X-228.002 Y+166.1 M99
9 L X-106.487 Y+157.861 M99
9 L X-29.002 Y+164.233 M99
9 L X+28.999 M99
9 L X+106.484 Y+157.861 M99
9 L X+227.999 Y+166.1 M99
9 L X+304.999 Y+130.225 M99
9 L X+302.999 Y-146.925 M99
9 L X+262.99 M99
10 L Z+50 R0 F3000 M2
11 END PGM 201RM10 MM..
right now conversational post processor output in below mention format
1 BEGIN PGM DRILLING_1-CONVERSATIONAL MM
2 TOOL DEF 17 L0 R0
3 TOOL CALL 17 Z S3
4 M3
5 M8
6 L Z-20 F M90
7 L X+31 Y-12 F M90
8 CYCL DEF 1.0 PECKING
9 CYCL DEF 1.1 SETUP 2.00
10 CYCL DEF 1.2 DEPTH -4.00
11 CYCL DEF 1.3 PECKG 1.00
12 CYCL DEF 1.4 DWELL 0
13 CYCLE DEF 1.5 F100
14 L Z+10 R0 F M99
15 L Y+77 R0 F M99
16 L Z-20 F M90
17 M9
18 M5
19 M30
20 END PGM MM
hope you will understand..also attach creo mfg test model files and both iso and conversational  pp
regards
FISA
asifcad
(To:asifcad)
sir still waiting your reply about postprocessor
