Post won't let RPM go above 10,000
jeuclide
8-Gravel
When I post a .ncl file my RPM's won't go beyond 10,000 even if in the paratemers they are at say 25,000. Any ideas how to fix this? Seems like it's a software issue setting???
Jeff
SteveLucas
(To:SteveLucas)
Jeff,
You can set it in the post also.
SteveLucas
(To:jeuclide)
Jeff,
are you sure it's a post problem? Iset my maximum rpm in the machine setup. like the picture. you can also set themaximum rpm in the site files also I know you have been using them just wondering if it got set there?rpm.JPG
SteveLucas
(To:SteveLucas)
Jeff,
Jeff
If you have GPOST, go to
Machine Codes
Spindle
then the Direct RPM Speeds tab.
Check the Maximum Speeds
If that doesn't work there may be something in the fil file that is limiting your speeds
Thanks guys, AGAIN!!! It needed to be changed in the GPOST as Steve stated. Now we are golden and new machine is running like a top!!!
Jeff
