Postprocessor for Siemens Sinumerik 828D controller
Francesco_Osti
7-Bedrock
Hello everyone,
I am looking for a post-processor for the controller Siemens Sinumerik 828D.
I have seen several posts about the Sinumeric 810D and 840D here in the community but none about the 828D.
Can a post-processor for a generic Siemens controller be used for the Sinumerik 828D? or should I create an 828D-specific post-processor?
Did someone develop a Sinumerik 828D post-processor?
Thank you in advance.
Francesco
1 REPLY 1
We have a CNC(DMG M1 with rotary axis) with the same control unit. I looked at the posts in the community and made a processor. I did a few tries on the machine and it worked fine. But there are some problems on the post output. I want to post first X-Y position then Z position line but some times processor doesn't work properly.  I attached the processor files and the picture that shows the problem. İf someone help me to improve this post processor I'd be appreciated.
Note: Tool_Name must be YES on the PPrint settings
