Gary, I'm afraid they don't make these things very obvious. I'm assuming you know how to set up a table with a Simple Repeat Region, and that you just can't find the parameter picks. Here's a sample four columns to get you started. Pick a cell in your repeat region, RMB, Report Parameter. Column 1: rpt...,index. Column 2: mfg...,oper...,ncseq...,name Column 3: mfg...,oper...,ncseq...,User Defined, TOOL_ID Column 4: mfg...,oper...,ncseq...,User Defined, PROF_STOCK_ALLOW As for "travel envelopes", I'm not sure what you mean by that. You can access any of the standard parameters as illustrated above. David
