Pro/NC Tool Path
unknown1
Pro/NC Tool Path
Hi everyone,
Is there a way that I can machine a surface (using surface
milling seq) in square pattern? I want to have the tool start at the
corner, then move in positive X, then positive Y, then negative X, then
negative y. I try so many different method under define cut but I don't
have any luck. The only thing I can the tool path machine in square
pattern is by using Trajectory Milling Seq.
Sincerely,
Thanh Nghi
Cad Supervisor
First Technology Innovative Solutions
Phone #: 734-254-1261
Fax #: 734-451-9549
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
