Can someone give me a quick advice how to achieve a tapping cycle at a federate of F.05? There are 2 options for tapping sequence are Fixed & Floating. I am trying to figure it out the formula but I have a little problem to understand when I read thru the manual - When I using fixed and set the Thread_Feed to .05 & Thread_Feed_units is TPI (because I am taping ü-20 tap hole)
When I using float I play around with Float_Tap_Factor & Spindle Speed but I don't get the result that I expected
Sincerely,
Thanh Nghi
Cad Supervisor
First Technology Innovative Solutions
Phone #: 734-254-1261
Fax #: 734-451-9549
