Problem mouse in EMX
gcambiaghi
I have a problem with the mouse in the mould base definition window, when I place the mouse over a plate it does not select to select it I have to move it either to the side or higher up,
has anyone ever had this problem? if so how did you solve it?
i have also tried with older versions but always the same problem.
gcambiaghi
(To:tschneyer)
Good morning to all
Problem solved.... I had to uninstall graphics card drivers re-install new drivers...the strange thing it didn't do it on all versions, anyway solved.
Maybe @tschneyer can comment your problem.
Martin Hanák
Hello gcambiaghi,
maybe it is a screen resolution problem. Can you tell me your screen resolution and your scaling factor (175%)?
Then we can try to reproduce and fix it.
Kind Regards,
Thomas
Kind Regards
Thomas Schneyer
B&W Software GmbH
gcambiaghi
(To:tschneyer)
Good morning to all
