Problem with equations in CREO NC
Hozaibergen
Hello!
In Creo NC Complete (5.0.4.0) when I create a new machine code for NC-machine, equations are automatically substituted.
CUT_FEED = (CUTTER_DIAM/80)*SPINDLE_SPEED*2
SPINDLE_SPEED = 150000/(3.14159*CUTTER_DIAM)
STEP_DEPTH = 0.1*CUTTER_DIAM
CLEAR_DIST = STEP_DEPTH+5
If I set my parameters (for example, SPINDLE_SPEED), they are updated to default anyway.
How can I change or remove these equations?
Please help me solve this problem
Thank You!
It works
mfg_assign_param_formula no
Here is an article that might help:
https://www.ptc.com/en/support/article/CS296827
Thank You!
It works
