Problems with units in Automatic Workpiece in Mold Cavity
ptc-4637347
Hello guys,
I have quite a trouble with Automatic Workpiece in Mold Cavity. I just cant choose any units in offsets. I have no idea why. I did some googling but couldnt find anything usefull. Do you have any advice? Thank you very much.
10 REPLIES 10
Inoram
(To:ptc-4637347)
Mine is that way, too. But I never use automatic (had to try it and see). Are on you on build m070?
You guys didn't install "mold component catlog" under option
Inoram
(To:gkrishna)
Oh good call. Just got my key this week, so should go do that...Maybe that will fix my runner issue.
Inoram
(To:Inoram)
Yup that was it. Had to have the catalog installed.
Thanks a lot 🙂 for this helpfull answer. But I did a little googling and guess it is quite complicated to install "mold component catlog" . I am at school and have no access to anything what I need to pay for. Does this mean that school did not buy this catalog ? Is it free ?
Inoram
(To:ptc-4637347)
In the regular version it is easy, it's just an option you select. In the school version I do not know. You can re-run the setup and see if the option is available. And I also don't know if it's free for school versions, for normal people it is the far opposite of free, it's expensive.
And where do select it if its there ? You go file -> options -> and now ? Because I tried to find mold component catlog there and I couldnt. This can mean, that it is not there in my version or that I am a very bad finder. 😄
Inoram
(To:ptc-4637347)
You have to run the setup.exe. Click Install or add software. But I am not sure your version looks like this.
But if you have it, click that and then click the command config tab and Edit your start command to start those licenses, too.
I am also having this problem in Creo 4.0.
Run setup.exe.
Select "Upgrade existing software".
Next
I Accept Agrrements (and all).
Next
Select License file if it's not there.
Next
In "Application Selection " Tab, click on 'Customize'.
Go to Creo Parametric tab
In right side, drop down "Option"
Select "Mold Component Catalogue"
Ok.
Complete the following setup.
Your Problem must be solved.
If not, send me message.
