ProductView 9.1 Pro Create watermarks
ptc-174577
2-Explorer
I am running ProductView 9.1 Pro on a client machine and trying to setup watermarks for Review state document but how do I create the watermark file?, it is asking for a *.ini file and my reseller has told me I can do it all from client side. Any help would be greatly appreciated. Regards Brett Reader
5 REPLIES 5
Darrell
(To:ptc-174577)
I think you have to use the watermark editor that installs with ProductView Standard 9.0.
I think you are right, but that hasn't installed with 9.1 client and I cant find it on the CD
You will have to install it from the PV standard CD
Regards
~Syed
llie
(To:shussaini)
The Watermark Editor does come on the ProductView Client 9.1 M060 install.
I just tested it again this morning.
PLease keep up the good work and conversations on ProductView.
llie
(To:ptc-174577)
After some help from PTC I was able to get the watermark to be read from PDMLink. The only issue is that I can not get any of the PDMLink parameters to be read into the watermark.
I am open to any suggestions and can help those that need to get started.
THank you,
Lance
