Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Is there more material left for Local Mill when cutting with Rough-Only parameter or Rough-Profile parameter?
Thanks for the help,
Byron Taylor Coordinator/Programmer
Danfoss commercial Compressors One Scroll Drive Arkadelphia, AR 71923 E-mail: byron.taylor@scrolltech.com Tel.:870-246-0750 This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
