Original question:
Anybody knows what's the PTC procedure/policy regarding floating licences.
Can an optional module be made floating. Can ANY module be made floating
or just some specific ones.
Answer:
The short answer is that some modules are OPTIONS (can float) and some are
EXTENSIONS (cannot float, but can be setup as startup licence to be picked
as a first come-first serve).
Some of the OPTIONS (that can be floating) are:
Pro/ENGINEER Mechanism Dynamics Option (MDO) (includes mechanism)
Pro/ENGINEER Tool Design Option (TDO)
Pro/ENGINEER Prismatics and Multi-Surfaces Milling Option
Pro/ENGINEER Production Machining Option
Pro/ENGINEER Complete Machining Option
Pro/ENGINEER Computer Aided Verification Option
Pro/ENGINEER NC Sheetmetal Option
Pro/ENGINEER Mechanica Option
Pro/ENGINEER Advanced Mechanica Option
Pro/ENGINEER Fatigue Advisor Option
Pro/ENGINEER Advanced Rendering Option
Pro/ENGINEER Routed Systems Designer
Thank you everybody. I can tell this forum is a diamonds mine. It worth a
thousand customer service centers.
Thank you Rui, Tony, Chris, Tim, Ron, Scott, Francois,Jeff and others.
