Sheet Metal Flat State Calculation difference between PRO-E & Inventor.
ptc-4753077
Hello ,
I would like to know how any of you have managed a transitition from Autocad Inventor to PRO-E for sheet metal components, especially for flat state.
Current Scenario in my organiztion : Inventor is used for developing sheet metal drawings. The Flat state dimensions for Sheet metal component is also given in the same drawing. This is done by inputting the k-factor values as per sheet thickness and material.
After migration to PRO-E , for the same sheet metal component , after inputting the same k-factor value , we have a difference in the flat state value of the sheet metal component.
This could have an impact on the sheet metal component during manufacturing.
Why does PRO-E and Inventor throw up different flat state values for the same k-factor , thickness and Material?
Has anyone come across a similar scenario?
9 REPLIES 9
If u site an example we might help you, however u can manually calculate for one sample case the developement length and can decide which software is giving correct development length,
Please find attached an example. A sheet metal part of dimensions 30*60*2. I have attached flat state views of both inventor and PRO-E for reference.
Assuming the internal bend radius is equal to thickness. please confirm the same, also provide the k factor you have considered for the model.
Hello Jayanta,
Thank you for your input. I have realised what I was missing. My internal bend radius in the Inventor and PRO-E models were not consistent.
Now I have set them to the same values and finally my flat state dimensions are consistent across both the Cad packages.
Appreciate your help.
I have posted one more query related to the same subject :http://communities.ptc.com/message/245238#245238
Please let me know if you have any inputs on the same.
Shibin
The flat state length generated in Inventor is 86.5 and 83.39 in PRO-E . (Dimensions in "MM")
Shibin,
I can see different value on the picture...
Inventor is 86.5 and ProE is 86.39 mm ... the difference is 0.11 mm
Martin Hanak
Martin Hanák
Shibin,
I didn't find bend radius of your model. Please upload your model.
Martin Hanak
Martin Hanák
Hello Martin,
Shibin
