I have a very large manufacturing file and when I want to work in the pro/program it takes a long time to open.
I use notepad++ to read the file.
What can I do to reduce the file opening time?
Try increasing the amount of RAM.
Already increased but nothing changes.
The % CPU usage is low, and the RAM even if the increase doesn't use more.
As if the CAD is slowed down.
Are there any settings to increase CPU and RAM usage?
What version of Creo and Windows OS?
I use Creo 8 and Win10
Found some another tip in "Creo Stability Troubleshooter" (and instructions to generate logs with the Creo System Monitor😞 https://www.ptc.com/en/support/creo-stability-troubleshooter/general-stability/not-responding
