Solution - Pro Piping Help.
CBenner
Here's what I found. The pipeline that was already in existence, was created as a stand-alone in Pro-piping using the ASM_DEF_CSYS as it's start point. It was then assembled to the machine frame in standard assembly mode (outside of Pro Piping). My first few unseccessflu attempts were to attach a new pipeline to the end of that one, using the PORT on the end of the last fitting of the pipeline. Apparently, when a pipeline is created as a stand-alone like this, and then dropped into another assembly... any new pipelines coming off of that, must ALSO use the ASM_DEF_CSYS from that pipeline as the start point..... not a PORT as one might expect with piping. Anyway, once I tried that I was able to get moving again. Thank you for all your great ideas.
Chris Benner
Designer II
Powell Fabrication & Manufacturing, Inc.
<u>www.powellfab.com
P: 989-681-2158
F: 989-681-5013
</u>
Chris Benner
Autodesk ® Expert Elite
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
