Survey Invitation for PTC’s Concept Design Study
ghedges
Parametric Technology Corporation (PTC) is conducting a survey as part of a study to learn more about the role and impact of concept design in product development.
The survey seeks to understand current attitudes, trends, and tools used in the earliest stages of discrete product manufacturing. From this survey and other research, a final report of the key findings will be published.
We urge anyone involved in the development and manufacturing process in any role to contribute. Individual surveys are confidential and identifying information about you will not be published.
Our testing suggests that it will require 20–30 minutes to complete. Please complete this survey by Sunday, July 31, 2011.
We appreciate your time and valuable inputs and as a thank you, each participant is entitled to receive a pre-release copy of the final report findings from the study.
In addition, five survey respondents will be selected at random to each receive an Apple iPad 2. The draw will take place on August 1, 2011 and the five lucky respondents will be contacted directly via email.
Thank you for taking part in our survey.
Best Regards,
Geoff Hedges
PTC Marketing
5 REPLIES 5
The link does not work
Shouldn't have to.....the link should work without having to edit it!!!
Absolutely right. Apparently an error occurred while inserting link using the appropriate menu "Insert link" when composing a message.
Iain, the original link to the survey should work now. There was a small typo.
-Dan
