T-Code is Modal still outputs an M06
mrego
I and setting up a post for a Leadwell V-60i and need to set the Tool as modal. When I set this option in the Tool Change Sequence output options to "T-code is modal" it will stop posting the T code but still posts an M06.
How can I set up my post not to post an M06 when the T code is modal?
Does any one have a post for this machine that they can share?
Mike
The code Ken supplied should have worked except with out pre-defining the variable CUTOOL you will get FIL errors.  Here is some simpler code you could try...
$$ This variable goes in the Global Section
LSTTN = 0                      $$ DEFAULT LAST TOOL NUMBER TO ZERO
CIMFIL/ON,LOADTL
  TN = POSTF(7,4)          $$ GET THE CURRENT TOOL NUMBER
  IF(TN .NE. LSTTN)THEN
    XX = POSTF(13)          $$ PROCESS TOOL CHANGE...
    LSTTN = TN
  ELSE
    CONTIN                      $$ DO NOT PROCESS A DUPLICATE TOOL CHANGE
  ENDIF
CIMFIL/OFF
Fred
8 REPLIES 8
KenFarley
(To:mrego)
If you are editing one of the GPost files, I've got a piece of code from one of my post-processors that handles tool changes. I didn't like the way tools were output by default and have always liked to have an optional stop after a tool change so I can verify the tool and its acceptability when doing the initial program tests. Here's the bit of FIL code:
----- [ Begin Code ] -----
$$ --[ LOADTL ]---------------------------------------------------------
$$ Handle a tool change to ensure that the machine is moved to the home
$$ position, that the outputs are in the desired format, etc.
CIMFIL/ ON, LOADTL
  $$ Obtain the tool number requested from the current line. If the tool
  $$ number called for is different from the current tool, process it in
  $$ the appropriate fashion. Otherwise, ignore it.
  TLNUM  = POSTF ( 7, 4 )
  IF ( TLNUM .NE. CUTOOL ) THEN
    CUTOOL = TLNUM
    $$ Write preparatory lines.  Some of the machines need to be
    $$ in the home position to properly load tools, so we might as
    $$ well default to moving there.
    INSERT/ 'G00$'
    INSERT/ 'G49 G28', REPEAT, 17, ' ', 'Z0.0000$'
    INSERT/ 'G91$'
    INSERT/ 'G28 X0.0000   Y0.0000$'
    INSERT/ 'G90$'
    $$ Output the tool change and an optional stop.
    $$ "IN2TXT" is a routine that makes the tool number, in this case, 2 digits
    $$ of text. For example, 2 becomes "02", etc.
    CALL/ IN2TXT, INTVAL = TLNUM, NUMDIG = 2
    INSERT/ 'M06 T', TXTVAL, '$'
    INSERT/ 'M01$'
  ENDIF
CIMFIL/ OFF
----- [ End Code ] -----
You could change this stuff to output things the way you want.
mrego
(To:KenFarley)
Thanks Kenneth,
I tried that FIL code but it still posts out the M06.
See example of post below.
G01 Z.1 F196.
M48
M05
G0 G17 G20 G40 G49 G69 G94
M06        <- This is what I need removed when the post is set to T-Code is modal
G54 G90
MIke
CIMFIL/ON,LOADTL
    LSTTN = TN
  ELSE
  ENDIF
CIMFIL/OFF
Fred
Fred,
Thank you that worked!
Yes, I always predefine my variables in the beginning of the program, especially if I'm going to be using them within other macros. I use "CUTOOL" to determine whether other stuff should be done as I process the file. Languages that require definition of variables are much less error prone.
Languages that require pre-defenition of variables still do not set the given variable to a default value, C++ for example.  You still have to give them a default value if they may be used before being defined.  Our RESERV/name,value (Sub Scripted) variables are a good example of this.
Fred
My trouble with a lot of languages that do not require one to define variables, like this one, is the inevitable "typo" bug. Where you meant to type INDEX, but accidentally typed INDEXX, and now your program doesn't seem to be working. Or worse, the nefarious "O" instead of "zero".
mrao
(To:mrego)
Hello~~
I think you need to select "Not Available" in "Auxiliary Code" then M06 code not generate.
Have a good day!!
Mark Rao
