T-Code is Modal still outputs an M06
I and setting up a post for a Leadwell V-60i and need to set the Tool as modal. When I set this option in the Tool Change Sequence output options to "T-code is modal" it will stop posting the T code but still posts an M06.
How can I set up my post not to post an M06 when the T code is modal?
Does any one have a post for this machine that they can share?
Mike
