TPE molding
mcaoyl2
TPE molding
Dear Progurus,
I have a part which is going to be molded with TPE.
The problem is the deep undercut slot in the middle.
The cross-section of the part is as attached.
Is there enough space to incorporate a slider for the undercut area?
Is it possible to force release the part with 3mm depth undercut?
What other options are available to mold out this kind of part with TPE
material?
What are the important aspect to beware when molding TPE product?
Is the draft of 4 degree enough to release the product?
Any good link to get info from?
Thank you very much in advance.
Lily
0 REPLIES 0
