Hi
this is the online Creo 7.0 help link on how To Create an Auxiliary NC Sequence:
But I can't find it in Creo 7.0 . In Creo 6.0 it's the same.
I have the Creo 2.0 installed and there I can find it.
Any idea how To Create an Auxiliary NC Sequence with Creo 7.0 ?
Sorry,
That was supposed to be enable_classic_nc_steps yes
Pushkar Khanna
@mdenicola wrote:
Hi
please ask PTC Support. Maybe you have to set some config.pro option...
Use the hidden config option enable_classic_cutline yes,
Then you will find aux nc sequence
regrads
Pushkar Khanna
Sorry,
Pushkar Khanna
Hi
yes, with the config option:
it's working
Thanks !
I just put enable_classic_nc_steps in the find now box on the config editor of Creo 6 and nothing comes up. Am I missing something here
enable_classic_nc_steps option is hidden. If I were you I would open config.pro in Notepad and add the option at the end of the file. Creo restart is needed.
