Tolerancing for master model technique
ptc-267878
wildfire 4.0
Using master model technique to create parts that interface with each other. After these 2 parts have been created, how does one go about adding tolerancing/gaps for manufacturing/assembly purposes?
The picture looks like you are showing a x section thru the mating surface. So at this interface, use the parting plane surface to cut/define one part's mating surface and use an offset of the surface to cut/define the other part's mating surface.
Patrick Fariello
CommScope
1300 E. Lookout Dr. Suite 150
Richardson, TX 75082
Perhaps you should look into using a skeleton at nominal and offset each part.
