Tool Path
byron.taylor
Tool Path
In Wildfire4 I use a volume mill with a mill window. When I run the tool
path it shows the path taken with a red line from the center of the
tool. When I try to move the part to see where the path has been the
lines disappear. How do I keep these lines visible so I can see where
the path is.
<<presentation1.ppt>>
Byron Taylor
Coordinator/Programmer
Danfoss commercial Compressors
One Scroll Drive
Arkadelphia, AR 71923
E-mail: byron.taylor@scrolltech.com
Tel.:870-246-0750
Hi Taylor,
On the CLPlayer click on "position cutting tool". WF will allow you to click on the toolpath while seeing it entirely.
HTH
Daniel
Daniel Santos
Suporte Aplicações CAM
GE Oil & Gas
T +55 11 4772-3565
M +55 12 8173-6567
F +55 11 4772-3775
Rodovia de Acesso João de Góes, 2300
Jandira - São Paulo - 06612-000 - Brasil
Vetco Gray Óleo e Gás LTDA
GE imagination at work
