Tool Setup problem
ptc-1193627
Tool Setup problem
i am using pro/manufacturing to create maching cutter paths. my problem is that when i create a tool and set its parameters i still end upo haveing to program the speed, anyone who is using pro/manufacturing and has gotten this problem to stop please advise me thank you Nick Troutman
6 REPLIES 6
Nick, You didn't mention which version of Pro you are using. There is a difference between WF2 and WF3. Regards
i am running wf3
Nick, Speeds/feeds are created relative to Stock Material. In your pro_mf_tprm_dir folder will be a file called mfg_wp_material_list.xml. Edit this file with Wordpad to add in the materials you wish to have appear in the Stock Material drop-down in your Operation Setup dialog box. It will look something like this: <?xml version="1.0" encoding="UTF-8" ?> - <MfgWpMaterialDoc> <DocType>PRO_NC_WORKPIECE_MATERIAL_LIST</DocType> <DocTitle>Workpiece Material List</DocTitle> <DateTime>2006-08-31T07:34:01</DateTime> <ApplicationInfo AppName="Pro/ENGINEER" AppVersion="M020" /> - <MfgWpMaterialList> <MfgWpMaterial Name="303_SST" /> <MfgWpMaterial Name="304_SST" /> <MfgWpMaterial Name="316_SST" /> <MfgWpMaterial Name="Aluminum" /> <MfgWpMaterial Name="Cast_Iron" /> <MfgWpMaterial Name="N678" /> <MfgWpMaterial Name="Plastic" /> <MfgWpMaterial Name="Steel" /> </MfgWpMaterialList> </MfgWpMaterialDoc> As is typical of ProE, there are no spaces allowed between words. Once you have your materials established, you can create/edit and save the speeds/feeds for your particular tools based upon Stock Material. It is important that you define a Stock Material in each operation setup you have. Then, when you are in the Parameters dialog while creating a sequence, you do Edit>Copy From Tool and choose which type of parameters you want. Failure to have a Stock Material will result in no data being populated. Additionally, in Wildfire 3.0 there is a new config.pro option called mfg_param_auto_copy_from_tool. Choices are all, cutting, no, and misc. Roughing, volume, re-roughing, and local milling sequences use Rough values; all other toolpaths use Finish values. Personally, I think this was an unfortunate and ill-advised specification to use. Who is to say that a holemaking cycle is Rough or Finish? Or a trajectory? Anyway, that’s the paradigm as nonsensical as it seems at first (and second and third) glance. Regards[/b]
Thank you Nick Troutman
i know this is a dumb question but where is my pro_mf_tprm_dir folder located i cannot seem to find it or what directory is it located in
You can edit/create it using Tools>Option from within ProE. Alternatively, if you look in your config.pro file, which is located in your <loadpoint>\text folder you will find it. If it isn't there, you need to add it as well as a fully-qualified pathname. Having a good config.pro is pretty important. You will want to back this file up or have another method for managing it so you don't lose it when you update your datecodes. Regards
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
